dpsguard »
https://forums.nicoclub.com/dpsguard-u207864.html
Mon Aug 06, 2012 11:47 am
Hi All,
Greetings from Canada. I am new to the forum and just bought a good condition 2008 M45X. All is well and I am very happy so far. The car had front passenger side tire pressure showing up as ** on the screen, plus the tire pressure check light. I checked the tire pressure and all tires had about 35 psi. So I took the car to the local Nissan dealer and they changed the sensor (parts and labor and taxes about CAD$212). They told me that code scan came up with sensor bad and all else was good. After driving about 15 minutes, I found that I have the check light back on and the screen again shows front passenger tire pressure to be **. I took it back to the dealer and they told me that it is because of bad main battery and showed me a test result which tells that battery capacity is low and it does not meet the industry standard. Assuming the battery is about 4 and half year old ( I have not seen it as it requires removing three or four plastic covers in the hood), and I never noticed any start up or ignition issues, I am puzzled as to how is the battery state affect one of the sensor to display incorrect readings ( that may also imply that sensor may not have been bad in he first place, which they replaced).
Please advise. I need to take the car back to dealer on Wednesday for replacing battery (if this is old battery, I will like to get it replaced anyway ahead of winter). The price quoted was approximate $160 (parts department was closed by then late afternoon saturday, so service adviser just estimated the price) and half hour of labor.
Thanks so much and God bless you all.
dpsguard
