merlinq2 wrote:I have an 07 X and I have the same complaints, the car hates bumps. If hit the gas and the rear end squats over a bump or un even pavement, the rear end knocks, almost as if it is bottoming out. Dealer says "Nothing we can see, next time take the tech for a ride and let him hear it". I think the car just needs better springs all the way around. Many have done the spring swap (Tein or H tech). I am not sure if that will solve the problem but it might just help the rear end be more compliant.
Back in the day I had a 5.0 mustang and when I pounded on the gas; the rear end would become very loud, that car hated anything but super smooth asphalt. I think these cars suffer the same issue, the rear end geometry and hardware just can't support the car.
So now I just drive better and I know how to avoid the noise if I want to.
Good luck
That clunk or knock that you get while heavy on the gas pedal over bad bumps or un-even payments will not be fixed by changing to new springs.
I had it with stock springs, H-Tech and now with D2 Racing coilovers.
It sounds like it's coming from inside the rear or inner axle. I was told it was normal on all M's.
