M45 TPMS sensors
adrdsouza
Car: 2007 M45 base
Hi,
Two of my TPMS sensors do not work and the local dealer wants $100 for each. I can get Dorman or Standard TPS sensors for less than half that on carparts.com.
Would these sensors work fine and sync with the other 2 OEM sensors and with the system? Which is the preferred brand for replacement TPMS sensors?
Ilya
You can get a set of 4 OEM ones on EBay dirt cheap. I just bought 4 for my new 20" wheels for like $50.
adrdsouza
Car: 2007 M45 base
Thanks a ton! i've found a few! What does valve cores not included mean? Is that the pin like thing that tire shops put into the valve? Not having that isn't a great deal is it?
Ilya
I think so, I just had mine installed and they had order them for $4.82/ea. Honestly, not a big deal.
Larz
Car: 2019 Q70-L RWD
I had mine installed by tire rack when I bought new tires and wheels from them. I believe they were about $50 each (installed) and Tire Rack mounted and balanced the tires free and shipped them to my local shop. After the new wheels were placed on the car, the TPMS had to be activated at the dealer but they worked just fine and continue to do so.
