M45 sport wheel fittment to 2005 G35 sedan
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
herman
Car: 2005 G35 Sedan
I have purchased a set of wheels,2005 M45 sport for my G35 sedan 2005 non/awd.. I tested the rear wheels and it is a go 245-40-19..well i tried the front set i notice they rubbed. My qustion is do i need to change tire size, or run spacers..? need a some feed back on this from someone that came across on this issue.. I plan to lower also with tanabe springs too about 1 inch..
Please give me some direction..
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
you have to run spacers when running the m45 wheels on the sedan. the oem offset for those wheels is 50mm. you need to run a 20mm spacer on them.
herman
Car: 2005 G35 Sedan
What if I ran 235/40/19 to the front 245/40/19 to the rear. Can i user a 15mm for the front? Why would i need a 20mm spacer for the rear when the wheel has clearance?
Herman
RED_DET
Vendor
2011 Infiniti G37x
You have clearance, but the wheels look sunken in and by adding spacers you will achieve a better look.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
