auditech10 »
https://forums.nicoclub.com/auditech10-u38958.html
Wed Apr 25, 2007 6:00 pm
the 85126+ are a good bulb to get but you still might have different colors to worry about, sometimes. There are a few options for OEM manuf. bulbs. There is the 85126 Philips, 85126+ colorshifted, Osram 66050, or the Philips 85126 WX which is the Ultinon 6000K(which is what I am running and I think they are worth the money!), and if you really want the 3000K(yellow) Philips 85126 YX. They are all made by the OEM suppliers Osram and Philips and are the ONLY bulbs that I would ever use, Im even iffy about using rebased bulbs from aftermarket HID kits. Do a search on Ebay and you should find a price you can deal with. I have to inform you that there a lot of copy cat bulbs out there, make sure you buy from someone that has a high feedback rating. And to second what nmgoodthing said, you should look into just replacing the pair and not just one. Oh and buying just one bulb from the dealership will run you $150 plus, just FYIcheers
