paperfootball »
https://forums.nicoclub.com/paperfootball-u68511.html
Tue Dec 18, 2007 3:42 am
Just a little story that will perhaps save some of you the headache(CN at bottom)!
When I purchased my car in July of this year the dealer only had one key fob—no big deal, I never drive the car anyways. I put off purchasing another key fob from ebay—I shouldn’t have!
Last week the battery in the fob was getting weak so I decided to replace it—no big deal. I took it apart, found the battery code, and went to Walgreens for another battery. After replacing the battery, the fob would not turn the ignition over, it would lock/unlock the doors.
I called Infiniti, they said that it probably lost its coding when the fob was apart for so long ( minutes). I would have to tow the vehicle in since I only had one fob.
Cool, I tow the car in, they attempt to use the emergency (metal) key from the fob to turn over the ignition—no dice. Finally, after cleaning about two inches of lint out of the ignition they get it (wth?). The key still will not work after attempts to reprogram it! The tech takes the fob apart and discovers that the transponder chip is missing—it fell out while I took it apart!
So my options are to leave my car there—that’s not happening, or buy another key. I mean, how much could a key be?
Parts: $368.07Labor: $110.00Expenses: $11.00 (?)Tax $45.25TOTAL: $534.32
CN= DO NOT LOSE YOUR KEY! Keep a spare!
