By manually removing them, and using battery power source to connect them(energizing them ), while using pressurised injector cleaner through the injectors. That's how it's been done here in my part of town, considering the cost of decarbonization services.EniGmA1987 wrote: ↑Mon Apr 19, 2021 12:15 pmHow did you manually clean your injectors? Normally an injector cleaning service is not equipment someone has at home nor is flow checking them afterwards.
Thanks for the feedback.EdBwoy wrote: ↑Sun Apr 25, 2021 8:55 pmIt seems like you have an electrical issue of sorts. That's the only way I can see you getting codes for all these seemingly unrelated systems.
I will answer a few questiins that you asked.
Re: Cam sensor (single - there's only one in the M45)
1. It rarely causes fuel consumption issues to a level discernible by most drivers
2. No reports of it discharging the battery
3. Yes, it can cause driveability issues such as randomly dying
4. It also typically manifests as starting issues
5. Unfortunately it doesnt always throw a code whennit becomes an issue, and thankfully it doesnt trigger wrong codes to mislead you.
The question on fuel is an interesting angle to iron out. Are you using premium fuel?
The 14.5V is fine, most N/I alternators output 14.1~14.6V on internal regulation. N/I CANbuses usually malfunction starting at about 15.5V, so even 15V will generally damage nothing but the battery.Dxta wrote: ↑Fri Apr 30, 2021 2:09 pmOne thing I'm still wondering is, what's the recommended alternator charging voltage? On my previous alternator, it was reading 14.5V, when not loaded. Immediately I load it with headlamps, radio, horn blaring, it drops to 14.2V. I was thinking this was wrong, so had to buy another alternator from a junk yard here. Installed it, and it was reading the same 14.5V on my multimeter.
Is this too high, or what?
Hmm, was there by chance anything rattling around inside the dead HVAC Unit? Maximas from the same timeframe as your ride have a nasty habit we call the "piggy bank". The HVAC Amps were directly underneath the shelf in front of the center display, and there was a gap between the display and shelf that could allow coins placed on the shelf to drop inside the dashboard. There was an open programming slot on top of the HVAC Amps that was exactly the right size for a penny falling down to enter. A nickel or quarter would jam the slot and you'd never have a problem, but a penny or dime falling through would short-circuit the HVAC and cause anything from blown fuses to a dead dash or even a shorted CAN bus. Nissan's fix was simple, new HVAC Amps came with a piece of tape over the slot. I wonder if it isn't possible your M has the same setup.
Thanks so much. Now o can rest knowing the output voltage from the alternator is correct.VStar650CL wrote: ↑Fri Apr 30, 2021 2:34 pmThe 14.5V is fine, most N/I alternators output 14.1~14.6V on internal regulation. N/I CANbuses usually malfunction starting at about 15.5V, so even 15V will generally damage nothing but the battery.Dxta wrote: ↑Fri Apr 30, 2021 2:09 pmOne thing I'm still wondering is, what's the recommended alternator charging voltage? On my previous alternator, it was reading 14.5V, when not loaded. Immediately I load it with headlamps, radio, horn blaring, it drops to 14.2V. I was thinking this was wrong, so had to buy another alternator from a junk yard here. Installed it, and it was reading the same 14.5V on my multimeter.
I looked at a parts diagram for an '06 (don't know what year you have) and the HVAC Amp isn't located in a danger zone like the Maxes. If your only issue is the blower and the Amp wakes up and doesn't blow fuses with the blower unplugged, then chances are you just have a bad blower. The M's use a BLDC (brushless) fan similar to the gen4~5 Altima, so there's no separate VBC, which makes it easy to check. There will be 3 wires into the blower, one small and two large. With the connector loose from the fan, measure voltage on the thin wire while moving the blower speed control up and down. You should see a changing voltage as you change the speed (usually negative, the voltage drops as the desired speed increases). If you see a moving voltage then the Amp is working properly and the problem is the blower.Dxta wrote: ↑Sat May 01, 2021 11:45 amThere was no noise that came from the blower area. It just suddenly stopped working.
Are there compatible blowers and AC amplifier ( the one attached on the side of the blower from any Nissan/Infiniti that can work for my vehicle?
Here's the part number of the amplifier: 27760 CR910
3W802 34710
My AC amplier, when I opened it open, I was it was blown around the mosfets or so. That means I got to replace the amplifier, and that's why asking if there are interchangeable ampliers that could fit, and also blowers that can work as well.VStar650CL wrote: ↑Sat May 01, 2021 12:45 pmI looked at a parts diagram for an '06 (don't know what year you have) and the HVAC Amp isn't located in a danger zone like the Maxes. If your only issue is the blower and the Amp wakes up and doesn't blow fuses with the blower unplugged, then chances are you just have a bad blower. The M's use a BLDC (brushless) fan similar to the gen4~5 Altima, so there's no separate VBC, which makes it easy to check. There will be 3 wires into the blower, one small and two large. With the connector loose from the fan, measure voltage on the thin wire while moving the blower speed control up and down. You should see a changing voltage as you change the speed (usually negative, the voltage drops as the desired speed increases). If you see a moving voltage then the Amp is working properly and the problem is the blower.Dxta wrote: ↑Sat May 01, 2021 11:45 amThere was no noise that came from the blower area. It just suddenly stopped working.
3W802 34710
There are no crosses, but there is a superseding p/n, 27760-CR95A. That's discontinued too, but there's a used one on eBay with 30-day returns if it doesn't work, $61.50 + $10 shipping:
Yes, your TCM is integral with the Valve Body.Dxta wrote: ↑Sat Jun 05, 2021 11:48 amDoes the TCM of this transmission, embedded insider the valve body as it's removed, just like you've it in Pathfinders, g35, etc?
There's like a small bunch of stuff like an ECU or harness at the side of the valve body removed. Might need to take some pictures and post here.
Glad you got it straightened away! Cam and crank sensors are more complex than people credit, because there are three different factors that influence them, electrical (the sensor supply and strength and voltage of the pullup resistor), magnetic (the reluctance of the wheel and sensitivity and topology of the Hall element), and mechanical (the gap between the sensor and reluctor wheel and the speed of the wheel). Analysis of all three goes into the OE selection of sensor characteristics. So even parts that seem identical in every way can be non- or mal-functional if they aren't quite what the OE engineers specified. That's why people's luck with cheap aftermarket CMP's and CKP's is so hit-and-miss. Even with OE parts, the occasional parts mixup is almost guaranteed to make everyone involved pull their hair out.Dxta wrote: ↑Sat Oct 02, 2021 6:31 amFinally!!! I have solved this stalling problem. All along, i was busy replacing the wrong sensor.
The part guys where i got the new Infiniti crankshaft sensor from, had new sensors, but i think, the sensor itself in the pack, was for a different infiniti vehicle. I had to spend enormous time researching the exact fit for the car, before I came across what the differences were, from the camshaft and crank sensors.
Huge differences, if one isn't careful.
Thanks everyone.
PS: i had checked the crankshaft sensor wiring diagram severally for potential reasons for the P0335 code, and it checked fine.
