M45 Hesitation - ECM?
marc_m45
Car: 2006 M45 Sport
2006 M45 Sport 88k
I've experienced intermittent hesitation while driving (prior post). I've tried many changes to attempt to fix the issue:
- camshaft sensor
- crankshaft sensor
- replaced air filter
- cleaned MAF
- replaced drive belt
The only thing that seems to improve the drive is when the battery is disconnected/recommected, and I perform the Accelerator, Throttle, & Idle Air resets. It will drive fine for a couple days, and then begin hesitating again.
Just the other day, I received a code U1010 (CAN Bus...). The service manual only states to clear the code, and see if it comes back. Is there a chance that I have a damaged ECM?
Ilya
If doing the resets works best...you may have a bad throttle body?
Iconic
Car: Nissan
Fuel/ignition related. ecm re-learns fuel maps when batt is disconnected.
check: coils,o2 sensors, plugs, injectors.
marc_m45
Car: 2006 M45 Sport
I forgot to mention that I did replace the plugs when all of this started. Coils seemed fine.
I've now had 2 mentions of the throttle body. Should none of these trip a specific code?
