M45 hard shifting when cold into 3rd
atlbird
My M45 is a 2006 with only 22,000 miles. The automatic transmission shifts smoothly at all times except into 3rd when cold. It seems more pronounced when under a load and when "manually shifting." Anyone seen a service bulletin on this?
NightWatch
Car: 2008 M35 Sport - Platinum Graphite
It is recommended that you let any car warm up some when it is cold before driving it. When your car is cold the fluids are less viscous and will result in things like harsh shifting which is actually the least of your worries. Risk of wear and tear on your vehicle is also higher when it is cold and I certainly wouldn't be doing things like putting the engine under load before it has had a chance to warm up some.
ken in az
Car: 2011 Infiniti M56
2002 Chevy Silverado
1989 Nissan 300ZX
2008 Ford F250 Diesel/Canam X3 Turbo
atlbird wrote:My M45 is a 2006 with only 22,000 miles. The automatic transmission shifts smoothly at all times except into 3rd when cold. It seems more pronounced when under a load and when "manually shifting." Anyone seen a service bulletin on this?
Yes, there is a TSB out it has been posted here before I beleive. Your service writer should know about it.
DashingMax
Car: 2006 Infiniti M45
2013 Infiniti M37S
"SEARCH" is your friend. After much ado, the TSB does not do anything.
