M45 Gauge Cluster Is Out No Lights or Movement!!!!
EHILL
Car: 2006 M45
Hello new to the club.......
I need a little help. I have no light or movement on my gauges (Speedo, Tach, Temp, and Fuel).
Many thanks.
DashingMax
Car: 2006 Infiniti M45
2013 Infiniti M37S
Hopefully it is under warranty. If not, your best option is to buy a used cluster from a junkyard (or new from dealer). You may install it yourself, however, the dealer will have to reprogram it into your car.
Good luck!
EHILL
Car: 2006 M45
It's still under warrenty at 55,900 miles. So this wouldn't be a fuse problem?
THX....
M4T5
Car: 2007 Infiniti M45
It is possibly a fuse.....but, if it is under warranty let them figure out exactly what it is.
J
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
It could be a fuse but depending on exactly what is not sending the supply signal providing an accurate guess is not going to work.
There are three or four control (depending on options) that need to be powered up to send the signal to the combination meter.
If it's under warranty the best advise I can give you is don't touch it and take it in as soon as possible.
EHILL
Car: 2006 M45
Thanks guys, it's going to the infiniti shop on Tuesday. I post the results of what the inifiniti dealer comes up with....
Regards,Eric
M45Caliber
Car: 03 M45, 54K mi, Pearl, Chromes, Frozen Rotors/Hawk pads, 5000K Fogs, MagnaFlow Exhst, Lip Spoiler
and BUY the freakin' extended Infiniti ELITE warranty -- as these puppies are expensive to repair. Also -- just as an FYI, you can buy the Elite warranty and it goes into effect the SAME DAY you buy it. So, you could like, maybe have a little "issue or problem" put perhaps it's "intermitent" (hint, hint). So you CALL Courtney at Scottsdale Infiniti and BUY the warranty... she faxes you the papers that day, so you're covered. Then damn if the next morning, when you start your car, the freakin' instruments are not working AGAIN. Can you believe it? Good thing I have that warranty....
