I see you are in jamaica which isnt far from me. lolI do have the megan axle backs on my M45 and have sound clips if your interested.dspratley wrote:I am thinking of swaping out the stock mufflers for borlas, has anybody done this, who knows the inlet diameter?
I see a lot pf people use the Megan replacement mufflers, how do they sound?
Modified by dspratley at 6:15 PM 4/8/2009
Modified by dspratley at 6:41 PM 4/8/2009
Everyone knows it's impossible to increase the performance of your car just by adding an exhaust! Infiniti engineered the factory system with millions of dollars to make the exhaust the best ever. It is fruitless to try to get more power and you'd be a fool to try. To think some muffler shop guy knows more than infiniti.nmgoodthing wrote:You will need a custom one made. I had my fabricated and am very happy with it. You will have to go Y pipe on back and depending on your muffler it will be pretty aggressive due to resonator deletes, so make sure that is what you want before you drop coin to do it. I love mine. It's throaty, no drone, and once broken in I got better gas millage and more power.
Altitude kills - only replacement is boost. It can still be a daily with a snail in the back. Or two snails beside the trans - well that'd be tight. Running 4-5lbs intercooled with an UpRev tune and add a VB shift kit and it would still be just as reliable as stock. 4-5lbs is really nothing and will increase output to close to 350-380rwhp.nmgoodthing wrote:Thank god my sarcasm radar is on.
In short, I live at 5300ft altitude. Our cars choke up here and before I had the exhaust done I ran a 15.6 @ 91 in the 1/4 in my loaded 4200lb y34.
Few weeks ago I ran 15.03 @ 95. That's a pretty good improvement if you ask me. If it wasn't my daily I'd throw twin snails on the b****, bu that is what my Z is for.
Wow, I just re-read your improved time, that is quite a gain! That's like 30hp! For the first run you must have had a serious headwind and a knarley low pressure system going on that day at the track. But non the less, it is an improvement!nmgoodthing wrote:Thank god my sarcasm radar is on.
