M45 engine ticking
trayday
Car: 2006 M45 sport
Only after I drive my car hard there is a ticking in the engine that sounds like a lifter knock for a while but then will go away. Only after I drive my car hard does this happen. It will also get quiter then loud again before it goes away, and stays with the engine speed. Any ideas?
splix
Car: 08 M45X
slack in the timing chain
trayday
Car: 2006 M45 sport
is that bad or natural? will i have to replace?
zerg711
Timing chain?! That's a new one.
The first thing you should do is to check your oil level before you do anymore driving. V8s are known for drinking engine oil.
trayday
Car: 2006 M45 sport
Oil levels are always fine, i'm always checking and changing every 3-3.5k
myother45isalesbaer
Car: 2004 M45 Q70 awd,4.5
I agree with Zerg711. These engines are on the high performance side. They eat oil for breakfast, lunch and dinner. They do so more when you run them hard. I have found that when getting the rev's up to the higher end you need to check the oil level after any run when you are making that engine work to its max potential. For some reason that I do not understand and have never found a solution to, is that the design of these motors is somehow flawed in getting oil to all the places it needs to go when you run them hard. I have had the same issue as you have posted. I found syn oil to be the worst and now run dino oil at a heaver rate then what is recommend. That cut down on my oil burning and the valve train problems I was having.
trayday
Car: 2006 M45 sport
My cars engine does not burn oil, ive never had to add oil and i always check half way between my change. car does not burn oil. I do notice that when i rarely drive my car hard i never have problems. i only have problems when im beating on it for a good minute
Lo m35x
Car: m35x
my m35 does the same .....can it be the gas you use 87 or 91??? cuz our cars call for 91
zerg711
Lo M35x, You should start by checking oil levels then switch to 91 octane and punch the car couple of times. If knocking persists, you should check to see if you can isolate the knocking to the pulleys. If you confirm it's coming from the engine, then you probably have the same issue I had. I had my short block replaced by the dealer under warranty due to one of the cylinders being bad. Hopefully you are under warranty...
Lo m35x
Car: m35x
bought the car used prolly aint under warranty
seldomseen
Car: '12 Nissan Altima Coupe SR 3.5
'15 Lexus GS350 F Sport
5y/60k mile Bumper to Bumper regardless of owner. You may want to consider purchasing an Infiniti/Nissan Extend Warranty if your car still qualifies for one. If you intend on keeping your M35/45 for the next 3-5 years. You will very likely end up with some costly repairs.
Lo m35x
Car: m35x
yea i mite jus do that
SarasotaM45
Car: 2003 Infiniti M45
My car does the same when using heavier weight oil. What type and weight oil are you using?
trayday
Car: 2006 M45 sport
I only use 91 octane from chevron and i change my oil myself with Penzoil 5w30 platinum synthetic, every time i change my oil it is always full and i never have to add oil
