m45 bbk
mr056
Can anyone tell me how much the g37 bbk upgrade costs? And where I can find them?
papaupa212
Car: M35
:dblthumb: i got them real cheap from someone who totaled his g37s. got them for 600 with out the rotors. You have to get spacers if leaving the 19" m45 rims. also take off the plate that cover the rotors in the back (rear brakes) cost me about $1,100 :gotme
ebay has them
http://www.ebay.com/itm/OEM-INFINITI-G3 ... 692wt_1114
here's are pics of mines
Rishi1331
Car: 06' m45s
papaupa212 wrote::dblthumb: i got them real cheap from someone who totaled his g37s. got them for 600 with out the rotors. You have to get spacers if leaving the 19" m45 rims. also take off the plate that cover the rotors in the back (rear brakes) cost me about $1,100 :gotme
ebay has them
Will 15 ml spacers work?
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
You can get away with 15mm spacers. I would recommend 20mm though. 15mm clears but leaves little clearance between the rim and caliper.
mr056
So what else do I need beside calipers and rotors?
mexillis
Car: M45s
Brake pads, if you have oem 19"s spacers, brake lines, one bottle of brake fluid just in case. Best place to buy this new is from concept z performance. They have everything you need just dont get any adapter brackets since you don't need any. Everything minus spacers will be around 1600.
mr056
Could I get away with just doing front bbk? Can I reuse the stock brake lines? Thank's for the answers guys!
papaupa212
Car: M35
mr056 wrote:Could I get away with just doing front bbk? Can I reuse the stock brake lines? Thank's for the answers guys!
i bought the calipers, brake pads, g37s steel braided brake lines, 20mm spacers and rotors.
bbs350z
Car: 350z built tt
350z st track whore
m35x daily
evo 8- 30r sold
thatd look weird. girls dont get one titty done at a time, they get both. for the price, its half the cost of a stoptech front bbk, and you get all 4 corners. worthwhile upgrade imho, they look great, and my pedal feel improved by alot. i used the factory 370z lines that they came off of.
mexillis
Car: M45s
You could just do the front, someone on here did just that. It won't harm anything besides asthetics. From what I've read you can use the stock lines with an adapter.
mr056
mexillis wrote:You could just do the front, someone on here did just that. It won't harm anything besides asthetics. From what I've read you can use the stock lines with an adapter.
what kind of an adapter?
ria
Car: '07 OB M35 Journey
Adv Tech
Why a BBK? Are you tracking your M45?
mr056
I been changing the brake pads every 15000 miles. Also the damn rotors warp every few thousand miles. And thats with my wife driving it. I have a c6 corvette with 1000 horsepwer and 25000 on the brakes and they are only half gone.
mexillis
Car: M45s
concept z performnce has it from what I heard. I used ss lines for my set up. Idk what pads you're using or what I had but my oem pads are still thick and have over 35k miles on em. I did turn the rotors once and they warped again shortly after. Have you looked into the ebay set up people have purchased from here? Cheap and so far good reviews.
mr056
mexillis wrote:concept z performnce has it from what I heard. I used ss lines for my set up. Idk what pads you're using or what I had but my oem pads are still thick and have over 35k miles on em. I did turn the rotors once and they warped again shortly after. Have you looked into the ebay set up people have purchased from here? Cheap and so far good reviews.
I cant find that adapter anywhere. I I buy ss lines will they be a straight bolt on or will i need anything else.
mexillis
Car: M45s
The g37s or 370z w bbk, oem or ss lines bolt right up.
mr056
Last question guys. If I buy new the calipers have to be assembled or what are the shims and other hardware for? If I buy from salvage yard will they just bolt up.
ctsedan
Car: 2006 M45 blk on blk. 1995 s14 Sr20DET.
Calipers come all set to install, just get brake pads and those ussally have shims. its all 100% bolt on really. If you know how to turn a wrench you can do this without issues.
m4m
Car: 2009 M35S
mr056 wrote:Last question guys. If I buy new the calipers have to be assembled or what are the shims and other hardware for? If I buy from salvage yard will they just bolt up.
When I was looking to get my BBK, I bought rotors and pads but then I got very good deal on complete kit of calipers and rotors so now I have extra pair of Drilled Stoptech 14" Front Rotors and Centric Front and Back Brake pads for sale. Let me know if you are interested.
mexillis
Car: M45s
How much for the drilled rotors?
m4m
Car: 2009 M35S
mexillis wrote:How much for the drilled rotors?
PM sent
mexillis
Car: M45s
Tried to reply to your pm but it says you have them disabled.
