Ilya »
https://forums.nicoclub.com/ilya-u159401.html
Thu Feb 23, 2017 10:08 am
Coilovers can lower your car if you so choose, or they can be adjusted to have the same stock height if you're into that. They will come with the spring and strut/shock all in one assembly. Much easier to swap then using spring compressors, removing an old shock, etc.
If you can get KYB for all four, that's obviously the cheapest way to go. Also depends on how long you're planning to keep the car...if you're planning to sell it within a year, DON'T invest in coilovers.
