M45 20X10.5's???
M40FIVE
Car: 2006 Infinitiy M45 Sport
Anyone have any luck with 20X10.5's on the rear??? I want to order some Vossen wheels, 20X9 Front/ 20X10.5 Rear. Not sure what offset to go with, optimal tire sizes, possibility of lowering (springs), and any RUBBING??
New2Import
Car: 06 M45
You need coilovers or bags to run that size without rubbing.
M40FIVE
Thanks for the info....are you speaking from experience? If so, did bags/coilovers work for you with the 10.5??
paperfootball
I have seen 1.5's on your bodystyle and they stuck out like a d!ck on a fish--perhaps with the right offset and some fender rolling it could be done, but the set up would have to be perfect IMO.
New2Import
Car: 06 M45
M40FIVE wrote:Thanks for the info....are you speaking from experience? If so, did bags/coilovers work for you with the 10.5??
Research...its other forums than just this one but you cant post it or they will delete your post.
