MaxBolus »
https://forums.nicoclub.com/maxbolus-u65637.html
Mon Nov 19, 2012 12:42 pm
I am currently battling with cooling fan fluid leaks as well. There are several hose connections that you can check, easiest way to find them is to get a copy of the FSM. Page CO-19 has a drawing.
The cooling fan hydraulics are powered by the water pump, which has an integral hydraulic pump for the fan. Mine is currently leaking from behind this pump, so the fix will likely require a new water pump 8-[
One of the high-pressure connections to the fan motor is right on the top left of the water pump (facing the pump), maybe see if fluid is leaking from there, you may be able to fix it with a new O-ring.
For now, I'm just feeding the leak. (Power steering fluid.) If yours is low, you'll notice a whirring kind of sound from it.
