M37x lowering springs???
OrenA
Car: M37x
Does anybody know of any plans to release a lowering kit for the 2011 Infiniti m37x? How long does it usually take the manufacturers to release springs for new models? I would suspect that Eibach would eventually have something. Does the AWD cause a delay? Thank!
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Typically there is indeed a delay in production of lowering springs. However the most recent recession killed many companies R & D budgets, and they are still demand driven.
AWD Infinitis are not top priority to spring companies, as the M35x only had 1 set of springs after 4.5 years since it came out.
If you find springs for a Sport they most likely will not work properly on your car.
OrenA
Car: M37x
I have finally found lowering springs made specifically for the m37x! I found these through http://www.burtmanindustries.com. They arent listed, but he looked into it for me. They are from a big tuning company in Japan. A bit pricy after shipping, but I would rather go with something that has been designed for this car. I am going to try them out and I'll post how they look and feel.
OrenA
Car: M37x
Just put on the springs. It rides great. I wish it was a bit lower, but its the only spring set available for the AWD. 22" Vossen CV1 coming next week. Here are some pics:
EniGmA1987
Car: '06 Infiniti M35 Sport
While it could go lower, it actually does look like a big difference. I never realized just how high the M37x sat :eek: Hopefully your springs will settle just a bit more as well and bring you down a tad lower.
Looking good :)
InfinitiEric
You just made a sexy car even sexier :drool:
deepsky
Car: 2004 G35 MT6
That's looking great. What is involved with install? Did you do the work? Also, do you know if the same kit works on the M56x?
OrenA
Car: M37x
When they arrived, the sticker read Nissan Y51 4WD, with no mention of engine. You should call Jason at Burtman Industries and he can double check for you. He's pretty quick and accurate with this stuff. I got my springs in exactly 2 weeks after ordering. 717-469-4130.
The installation was done by a place called International Automotive and Customs in Toronto. It's not something that you can install alone. It cost $400. The dealership can do it as well, but they want around $1000 for the same job.
InfinitiEric
I can't confirm for the new models (M37/M56), but the previous aftermarket springs for the M35 and M45 were not interchangeable between the two models because the M35 and the M45 have different spring rates. I think I've seen someone the NICO forums install the M35 Tein springs on their M45, though. I wish there was more definite documentation on these things..
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
InfinitiEric wrote:I can't confirm for the new models (M37/M56), but the previous aftermarket springs for the M35 and M45 were not interchangeable between the two models because the M35 and the M45 have different spring rates. I think I've seen someone the NICO forums install the M35 Tein springs on their M45, though. I wish there was more definite documentation on these things..
That is correct. I, along with a few others have Tein H-Tech springs (which are said to be for the 35) on my 45 Sport
chuckbytes
Car: 2011 Infiniti M37x
I always thought the M sat about 3-4 inches too high, that Lowering Kit brought it down just enough
Almost a year to the day since you posted, not sure if you return to read but if you don't mind a couple questions.
Any issues with warranty, did you get it done a the dealer.
How has it affected the ride.
I would love apply the same system on my ride but couldn't find the kit on the link you posted. I'll contact the Jason for further details.
Thanks.
OrenA
Car: M37x
chuckbytes wrote:I always thought the M sat about 3-4 inches too high, that Lowering Kit brought it down just enough
Thanks.
I spoke to the dealer before I did it and they said it would effect the warranty. I haven't had any suspension problems, but the dealers may try to blame it on the springs if something did happen. I got it installed by a shop that does a lot of high-end customs. The dealer would have put them on, but they wanted like $1000.
The ride has got a bit harsher but not as bad as people got me prepared for. I also put 22's on around the same time, so that also takes away a bit from the ride.
I dont really have any regret after putting the new springs. Especially when I drive next to the stock version of my car. Check out everything I've done to it and some better pictures. http://www.cardomain.com/ride/3937053/2 ... iti-m-m37x
OrenA
Car: M37x
I forgot to mention that since I took those pictures the car has settled a bit lower. My cardomain pictures show that.
ddiimmaa
Car: M37X
OrenA wrote:I forgot to mention that since I took those pictures the car has settled a bit lower. My cardomain pictures show that.
Do you know what the actual measured drop was on the car? front vs back? if you still check this would be useful info! thanks
svard75
Car: 06 M35x
Hey OrenA. How did you remove the rear strut assembly to install the rear springs?
MachineGunJoe
Car: M37
Keep in mind the thread is a year old and the OP might not look on this thread anymore. It might be best to PM him since he's still active on the forums.
Jason B
Car: Infiniti Q45
I can get these for anyone still wanting or needing. Subscribing again.
DoN_BLaZe34
2006 FX45 - Traded
What were the springs used and how much are they?
OrenA
Car: M37x
BTW, this is how the car looked 3 years after installing the springs. It settled a bit. My lease ended last month, so the car is gone. I have the black painted OEM lights and the rims/tires if anyone is interested.
DoN_BLaZe34
2006 FX45 - Traded
OrenA do you have the springs?
Could you provide some details about them?
mksoucek
Car: Infinity m37x
How much are you asking for the Tail light covers
Ilya
mksoucek wrote:How much are you asking for the Tail light covers
Hi, welcome to the forum.
But, dude, this post is from 2011-late 2014...please don't bump crazy old threads unless it's pertinent to the discussion (such as regarding M37x lowering springs). It will help keep our forum clean and organized. Please PM the user regarding the tail lights. Thank you.
UOFM37
Members, Please post pics and which springs you're using. Also, Has anyone had a bad experience with the Eibach prosport RWD version used on the AWD m37x with original struts ?
