M37 to Q70 Trunk conversion
BIGLIL215
Car: Infiniti M37
Hello I'am doing a M37 to Q70 conversion front end and back end. I connected the trunk, but the harness connectors are different. Does anyone know the proper way to connect the trunk connecter wires from the Q70 to the M37 harnessImage
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Nissan/Infiniti is funky with harnesses, sometimes they change harness manufacturers at the drop of a hat. Might be able to help if you provide the VIN for your M and the year for the Q trunk. Once the wires are identified, if you still have the connector from the original M Trunk Harness, your best bet is to pirate the connector off it for use as an interchange pigtail.
airmanhoward
Car: 12 M37-Current
08 civic lx sold
06 M35x Totaled
2000 S10 sold
Ford contour svt-sold
91 caprice-sold
90 & 93 maxima-sold
96 ford escort-sold
Where can i find info on this conversion??
BIGLIL215 wrote:
Thu Nov 26, 2020 3:42 pm
VStar650CL
Technical Expert
Unless some aftermarket manufacturer makes an interface pigtail to support the swap, you'll have to sort it out yourself from the two different wiring diagrams.
airmanhoward
Car: 12 M37-Current
08 civic lx sold
06 M35x Totaled
2000 S10 sold
91 caprice-sold
90 & 93 maxima-sold
96 ford escort-sold
I'm referring to a parts list if available. I can't find any info on the conversion just finished swaps. Zero info. I fell like I have to be in a secret M society 🤣🤣
VStar650CL
Technical Expert
Haven't done one and don't know. You could inspect the Q harness to see if all the business-end connections are in the same places using same connectors as the M harness. If so, just swap harnesses and use your old M.
VStar650CL
Technical Expert
Did a little digging in the ESM's, the trunk lock control unit on the Q has two wires running to the BCM that don't exist on the M. Not even sure if they can be added without changing BCM's. My guess is you have a can of worms here.
EdBwoy
I suppose it depends on what year M you are dealing with. In the US, the 2011 and 2012 models didn't have auto-closing trunks.
I don't have access to the manuals ATM, but I bet that might have something to do with the BCM difference VStar pointed out above. If you are comfortable re-pinning harnesses, you can make it all work...or switch over the hardware and wiring from your old trunk.
VStar650CL
Technical Expert
EdBwoy wrote:
Fri Nov 27, 2020 10:04 am
I don't have access to the manuals ATM, but I bet that might have something to do with the BCM difference VStar pointed out above. If you are comfortable spinning harnesses, you can make it all work...or switch over the hardware and wiring from your old trunk.
The WD's I compared were '12 M versus '14 Q. The problem is, if the BCM on the M doesn't have IO's to drive the latch, he may need a different BCM. That could be a huge can of worms vis the other systems in the car.
Ilya
airmanhoward wrote:
Fri Nov 27, 2020 6:30 am
post6765643.html?hilit=q70%20conversion#p6747547
This is the best you will get until one of you guys who's into doing these conversions actually does it and captures the steps/parts lol.
Yoda's Master
Car: 2012 M56
2009 370z
Just take out the old wire harness and trunk lock from your old trunk and move it over. I wanted to add the auto closure to my M, but decided not to since you need to insert new wires into the bcm.
VStar650CL
Technical Expert
I'll look into the open/close signal from the BCM and see if there's a kluje-fix. If it's a simple 12V strobe and not a bit-bang, it may be possible to use the existing trunk release signals for auto operation, or perhaps a DIY switch. Yoda's right regarding the rest, the M harness should get everything else working, there's no point in trying to use the Q.
VStar650CL
Technical Expert
It looks like the smartwork for the trunk opener is all in the opener/latch assembly, the BCM just outputs a 12V strobe "open signal" that's no different from the strobe to a conventional trunk lock. So if you can route power from someplace to the opener, you should be able to use the existing M trunk release line to trigger it.
ibc
Car: Infiniti M56x
Wait a minute... Doe newer M's have a different hinge that allows a motor to close the trunk lid? If so, can it be retrofitted to a 2011 M?
EdBwoy
ibc wrote:
Mon Nov 30, 2020 8:13 pm
Pardon me, I don't think I worded that as accurately as I intended to communicate.
The 2013+ models have a trunk "cincher" , which means you place your trunklid pretty much all the way down, then a motor pulls the lid down for that last half an inch. The power is at the lock mechanism, but you swing the trunklid up and down manually.
That is unlike an automatic/powered trunk, where the hinges are motorized and a button press will automatically raise or lower the trunklid.
To my knowledge, no Infiniti sedans in the US have ever had a powered trunk since the 2006 Infiniti Q45.
