m37 Spacers Ichiba OR H&R
ddiimmaa
Car: M37X
Ok.. Maybe im retarded at doing this... but when i measured from the tire to the fender i got 10mm in the front and 12mm in the back. H & R doesn't have anything for my car in 10 or 12. I know I could go with the g37s models or the jukes etc.. its all the same bolt pattern so who cares but the bore is different. 66.2 vs mine of 66.1. Does that really make a difference as far as fitment? I would prefer not go to ichiba as ive been seeing some bad reviews all over. Anyone have suggestions?
mexillis
Car: M45s
I have eibach 20mm spacers and 15mm ichiba with no problems so far. Idk how long the studs are for your car but some can accommodate a 10mm without needing longer studs. As for that .1 difference I couldn't tell you if you'd feel vibrations or not but getting the exact match of 66.1 is always best.
ddiimmaa
Car: M37X
Yeah Im going to measure again in a little bit so far i cant find anything for the car :/
