M37 2011 codes B2673 B2674
B52
Car: Infiniti Q45, 1993, Black Obsidian,
Infiniti Q45, 1994, Black Obsidian,
Infiniti Q45, 1993, Green,
Infiniti G20, 1995, Blue,
Nissan Xterra, 2005, Night Armour,
Chrysler Concorde LHS, 2002, Gold.
The diagnostic computer has detected error codes. B2673 and B2674. What is that ? Thanks for your help.
Ilya
I'm not too familiar with B codes but they are likely a subsystem like body or electrical and not emissions or engine.
armybrat
Car: 2012 M56x with Tech Package (sold)
Custom 2-1/2" X-pipe exhaust with OEM sport mufflers
HPS intake hoses
Uprev tune
There are several B26XX codes referenced in the FSM Body Control System .pdf in the HowTo & FAQs link above. I didn't see the two numbers you quoted. Are you sure they're right?
satown210
Car: 2012 Infiniti M37
2005 Nissan Xterra Off Road
Those codes seem to mostly point towards GM vehicles.
What are your symptoms and how did you get to those codes. I am wondering if you accessed saved codes in the scanner that necessarily don't pertain to your car.
EdBwoy
Thanks for clarifying that about GM vehicles satown. I couldn't locate these codes anywhere in the Infiniti manuals.
I also wondered, if the scan tool was good enough to pull chassis codes, why couldn't it give a general description of what the codes were?
But if some tools are able to store historical codes, then I see how that could be an error. I would clear the codes and read again.
B52
The car was tested with a diagnostic computer.
B2673 ACTUATOR RH (SHORT) 0
B2674 ACTUATOR LH (OPEN) 17
satown210
That doesn't tell us anything. Who tested it and how? What scanner are they using? What are you symptoms? What is going on with the car?
armybrat
HPS intake hoses
Uprev tune
B52 wrote:
Mon Feb 25, 2019 9:46 am
Just a quick google search.
Could be this:
https://repairpal.com/estimator/infinit ... ement-cost
I've seen threads about having blend door issues, temps and air direction to vents, etc.
Or this:
https://www.yourmechanic.com/estimates/ ... eplacement
This...not so much.
B52
Web pages do not open.
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
B52 wrote:
Mon Mar 04, 2019 8:18 am
hmm, I was able to follow those links.
my Google search turned up:
http://b2673.enginecodes.net/
http://b2673.enginefaultcode.com/
b2674.enginetroublecode.com/
satown210 is right, though - these codes are sometimes too generic. We need to know what is going on or wrong with your car in order for us to help point you in the right direction.
Some OBDII scanners are too non-specific. Ideally you need someone with a Consult 3 or 4, which is a computer designed specifically for Nissan/Infiniti (a Nissan dealer could read what's specifically wrong, you don't have to bring it to an Infiniti Dealer or a independent shop that specializes in Nissans/Infinitis might have one too)
help US - help YOU
Craig
