m35x xm radio Question
louiegsi
Car: 2006 m35x
So I have a problem with my XM radio it keeps saying acquiring Now in my mind i was thinkg it was the box I went on eBay got a new one should be here this week How can I gain access to the box to replace it ????
Boonies
Car: Current: Infiniti M45x
Last: Audi S8
I believe your box is accessed from the trunk, mounted to the under-side of the hat-shelf.
Later models like my 2008 are actually built into the radio cluster.
Partysan7
Car: 2008 M35
Not true I have 08 M and its in the trunk.
Op just pull out the liner and the module will be in upper right corner.
louiegsi
Car: 2006 m35x
its in the trunk Passenger side Very hard to get to Is it easier if I take out the back seat
merlinq2
Car: 2007 Infiniti M35x
No need to pull out the rear seat, drop the right side and top truck liners and in the top right corner you will see a bracket that has an amp in it. The XM module sits on top of that with two screws. The tricky part is running the antenna - do you have the shark fin on the rear roof? If not you will need to buy a magnetic antenna, based on the fact that you have an 06- you will need an antenna- check Crutchfield for that.
Check this link - page two image seven - location of the amp- and where you install the xm module
pa15-infi-t516192-30.html
louiegsi
Car: 2006 m35x
how can i tell with the antenna? this is a photo of my car i dont know if u can see the antenna or not
]Image
Image[
Larz
Car: 2019 Q70-L RWD
You already have the antenna - that fin-like piece at the rear of your roof. Assuming you have an active account with XM and are paying the extra fees for the XM reception, you can always call them whilst inside your car and they may be able to troubleshoot it for you. When I activated mine, they had me sit in the car and they tested signals, reception, etc.
louiegsi
Car: 2006 m35x
Larz wrote:You already have the antenna - that fin-like piece at the rear of your roof. Assuming you have an active account with XM and are paying the extra fees for the XM reception, you can always call them whilst inside your car and they may be able to troubleshoot it for you. When I activated mine, they had me sit in the car and they tested signals, reception, etc.
thanks for the reply do you have any idea why its doing that ? it wont turn to ch 0 for the radio id at alll it sounds like the box is no good yes ?
Larz
Car: 2019 Q70-L RWD
If your screen tells you it's trying to aquire the signal, but you can't tune to channel 0, it seems one of two things.
1) Your antenna may not be connected to the unit in the trunk. Have a look because some peeps have unplugged the antenna to add other sound devices.
2)You unit itself could be bad since it doesn't allow you to tune.
I'd jump into the trunk, remove the trim pieces and have a look at the unit. You'll have to do this to install your new unit anyway. If it's a simple matter of re-attachng the antenna, job done ! If it's already attached, then it would seem your suspicion is correct - the unit has gone titz-up.
Good luck and please post however this project turns out.
cruzad3r
Car: 2006 Infiniti M35x fully loaded
but i like titz lol - serious question, those who have XM account, do you pay monthly or yearly and do you have the channel BPM?
thanks
Partysan7
Car: 2008 M35
Right now Im still on a 3 months free trial and yes BPM is there Ch 51 . After my triall ends i'll go yearly.
Larz
Car: 2019 Q70-L RWD
I think Partysan and I did this at nearly the same time. When I called XM they offered me a 3-month free trial with no credit card info needed. That ends the 28th of this month. I received an Email from XM to switch to a regular account at reduced rate of $25 for the next 5 months, which I just did about 20 minutes ago. After my 5 months at the reduced rate, it will continue to renew at the regular rate (unles I cancel). I'm betting at the end of 5 months there will be yet another set of discounts offered. Seems they have a variety of ways to go. From what I've read at the website its basically about $45 for quarterly payments or a discounted rate of $99 for an entire year which is about half the quarterly rate.
louiegsi
Car: 2006 m35x
let me ask u this Is it possible to get xm Traffic or xm Weather on older m35 or just new cars
Larz
Car: 2019 Q70-L RWD
I was told that the unit in my 2007 was too old to receive those. I never bothered to check into upgrading mine.
cruzad3r
great info, thank you folks.
bluedevil30
Car: 2009 M35X
265,000 miles
louiegsi wrote:let me ask u this Is it possible to get xm Traffic or xm Weather on older m35 or just new cars
XM traffic isn't worth it even for the low monthly charge.
louiegsi
Car: 2006 m35x
so here is the deal , my friend works at the dealer i told him my problem , he said it can be 2 things the xm box or the ant, now here is my thing he said the ant on the roof is only for radio and xm not gps now my radio works ? i Get stations no problem im still waiting for the xm box i bought online i do belive its the box cause if the ant was no good then i will not have any radio Stations and i un pluged it from the back of the xm box and then it said error then i pluged it back in so idk what does this sound like guys ? xm box ? or ant ?
Larz
Car: 2019 Q70-L RWD
Not sure about the 2006, but on my 2007 I am told my radio (AM FM) antenna is in the rear window and the shark fin on the roof is for NAV and satellite radio.
louiegsi
Car: 2006 m35x
up date , got the xm box in the mail today i pluged everything in to see if it works and yes it does work !!! thank god its not the ant i hard thats a lot of money so it started raining in new york i have to put everything back togeter tommrow love the sound of bose and xm radio i just wish that cm radio shows the name of the song and i do t have to press audio text
louiegsi
Car: 2006 m35x
Xm radio is ok its not all that they have more rock then dance and hip. Hop I got a very good promotion 6 mons. For 29.99 $ all the channels
