The00Dustin »
https://forums.nicoclub.com/the00dustin-u137235.html
Thu Jul 30, 2009 7:28 am
Regarding 2006-newer, I don't think there was an M45x until 2009, but that doesn't much matter since you don't want the AWD. The only other thing I know of off-hand is that I have seen a lot of complaints about the interior trim (especially the wood) in this forum, and I could be wrong, but this appears to be specific to the 2007 model. Additionally, the 2006 model (front) passenger seat is pretty weak in terms of adjustments, no lumbar or front height adjustment on the tilt (even premium package). In a thread where this is brought up, someone said that changed in 2007, but I don't know whether that change applies to both the tilt and the lumbar or only the tilt. I bought a 2006 M45 Premium Package a month ago; it was manufactured in April of 2005, so I am crossing my fingers and hoping it lasts as long as an Infiniti should even though it was pretty early off the line. Another difference you will notice is the dash lighting color in the 2008+ models. In 2006-2007, the dash lighting is red and the rings are classic infiniti brightness adjusting light coming from the outside of the speedometer (these can be turned off). I haven't seen a 2008+ M, but I had a 2008 G35x loaner (it was very go-kart-y, if the M35x would be the same way, I am super glad I got an M45 instead in spite of the snow in my region with it being my only car), and the lighting was blue, but the ring was faux and could not be turned off. Personally, I thought the faux blue ring in the G35x was very tacky (though I'm sure a real one would be beautiful, and the M might have a real one). That said, if you have the option to go that new, you might want to compare the interior lighting to see which you like better, depending on how picky you are. I'm sure there are other subtle differences; hopefully others will chime in.
