M35x upper oil pan removal 2007
Jeffogto
Car: 2007 M35x
I'm trying to remove my upper oil pan without pulling the motor. My question is will I have to pull the front drive shafts out of the engine/transfer case to get the oil pan off? Thank you, any advice you might have is always welcome
Jeff
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
According to the FSM the whole Front Final Drive has to come out with all the shafts and axles, plus the subframe and starter motor. I'm a Nissan tech and not Infiniti, so I haven't done one, but from what I can see of the layout, I don't think you'll find many shortcuts. See EM-38 here:
https://www.nicoclub.com/service-manual ... 5%2Fem.pdf
Jeffogto
Car: 2007 M35x
Well I've got everything unhooked from the motor except the transmission and the drive axles. So I guess I've still got a few hours work ahead of me. Thanks for the help. It's a lot easier if you have a direction to go. Thanks much!
Jeff
VStar650CL
Technical Expert
:dblthumb:
Jeffogto
Car: 2007 M35x
I have run into a little snafoo, I've got the final drive all unbolted but can't get it separated from the block/oil pan. Any tricks you know of?
Thanks, Jeff
VStar650CL
Technical Expert
No clue. Like I said at the top, I haven't done one. Maybe one of the M mavens in here can help you out.
Jeffogto
Car: 2007 M35x
Thanks, Jeff
EniGmA1987
Car: '06 Infiniti M35 Sport
I only know how to unbolt the rear final drive, never worked on an X model and dealt with all that extra front stuff :(
Jeffogto
Car: 2007 M35x
Well I finally got the final drive housing down. Only bounced a little, lol. My car has 245,000 miles onit so I got bearings that were 1/100 ofam inch thicker. Guess what,too thick. Standard bearings still the right size. Well Made motor!
