Overall, pretty happy with it, with the exception of the higher than expected iron levels and the lower than expected viscosity at the end of the run.
One other quick note...The 0.75 qts that I topped up with was Mobil 1 5W-30 (what I had in the garage when I got the car back from transmission work), so I am sure that will skew the typical results of the Valvoline Max Life 5W-30.
Hope this helps others to compare and contrast...and any other thoughts and observations are always welcome.
I will definitely do another in 5,000 miles, or so, and will share those results, too.
