M35x Suspension Components
gravel21
Car: 2006 Infiniti M35x
Hello everyone. First time posting in the forum! I was curious on the differences on the suspension components on 06-07 vs 08-10, as well as AWD vs RWD. I own 2 07 M35x, and unfortunately one lost a battle with a stationary object and needs a variety of parts ie upper conrol, lower control, tie rod, etc aside from the body damage. Wondering what years I can pull parts from, if its worth fixing. Thanks
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Go to InfinitiPartsDeal.com and plug in your VIN, then look up the factory part numbers for what you need. Then clear the VIN and search those numbers with no vehicle entered. At the bottom of the page in the fine print, it will tell you what years and models the part fits. For aftermarket parts, RockAuto has a wonderful part number search tab which will find equivalents for factory p/n's.
