Here are some comparison pics.
Yes. I bought KYBs as the replacements.kmiles wrote:That's a great find - does KYB make a replacement for the G35x? I really like the KYB's shocks on the rear of my M35x.
I have an 06. I dont remember which part number though.ae7456t wrote:Great find...I am just about to replace the shocks on my M35X, and was looking for a cheaper option.
@Zoldier - What year is your M35X, and which KYB part numbers did you go with for the fronts (looks like they change for the G35x at '07)?
Thanks!
Thanks for providing the part numbers AE. Much appreciated!ae7456t wrote:I took a shot, based on the pictures, and was able to replace the fronts with these KYB parts:
KYB 340010 Excel-G OE Replacement Shock
KYB 340011 Excel-G OE Replacement Shock
They went right on, and so far, so good.
Those numbers look familiar. Pretty sure I got the same ones. I bottomed out pretty hard a couple of days ago. I looked them over today while rotating my tires and they still look good.ae7456t wrote:I took a shot, based on the pictures, and was able to replace the fronts with these KYB parts:
Yeah, wish i could get a quick strut with springs, but oh-well. I plan to rent one or two pair of compressors from auto store when i get ready to tackle the job.
How the heck do you get the front strut out of the car? I can't disassemble it. I've loosened the upper bolts and the lower bolts, but there is not enough clearance to wiggle it loose. Any tips?
Interested to find out what happened?TN_INFINITI wrote: ↑Sun Jul 15, 2018 10:20 ami got my struts off of my 2008 M35x and as i look at the KYB 340010 Excel-G, they do not seem to match up. It appears the KYBs are about an inch shorter. I'm reluctant to install them on my 2008. What happens if i install shorter struts?
They fit in there just fine, but the front end of car was lowered by about an inch, which affected my caster. I've since uninstalled them. I thought about installing front strut spacers, but decided to just undo everything.bgreen wrote: ↑Tue Jul 24, 2018 6:38 pmInterested to find out what happened?TN_INFINITI wrote: ↑Sun Jul 15, 2018 10:20 ami got my struts off of my 2008 M35x and as i look at the KYB 340010 Excel-G, they do not seem to match up. It appears the KYBs are about an inch shorter. I'm reluctant to install them on my 2008. What happens if i install shorter struts?
