[email protected] wrote:Need info on recommended plugs for M35X..not necessisarily OEM.Also procedure and difficulty changing them. Dealer wants $15/plugplus 2 1/2 hours labor at $80/hour....ouch
Be careful!!
Nissan and Infiniti engines are notoriously sensitive to using other manufacturers. Particularly, do not use Bosch, no matter how good they are claimed to be for other cars. They have a tendency to die inside Nissan and Infiniti engines, with electrodes breaking off and scoring cylinder walls, etc.!
Definitely stick with the OEM plugs manufacturer (NGK), but you do not have to buy them from the dealer if you don't want to. Try
http://www.everythinginfiniti.com and other places too - I have occasionally seen these on eBay, but you have to be sure that the seller is legit too.
Also, you can change to hot or cold type of NGK plugs, but this also comes with its own set of advise - use with care, depending on your driving habits, etc.
Z
