fxmercguy wrote:I just picked up a Certified 07 M35X with 24000 miles. On smooth roads, its awesome! On rougher roads, especially on highways, the car seems to shimmy from side-to-side. You know when you're on a road thats being milled and the car pulls from side to side a bit from the milling grooves? That's how it feels. I'm questioning whether there is something wrong with the all-wheel drive system. The dealer says this is normal and "due to the wide track of the car". I think its BS. I have an FX35 and have also driven the G, and neither did this on rough pavement.
I know the M goes mostly on the rear wheels on dry roads, so I cannot understand the way this car handles on rough pavement. It almost feels like as the tires are bouncing on the irregular road, the AWD system is trying to bring power to the other tires to get traction, which is causing the irregular side-to-side feeling.
Has anyone else experienced this? Is THIS normal?
It is the tires. I bet you still have the original Goodyear RSA tires on the car! If so, get rid of them, put on something appropriate for your part of the country (use summer tires now, and get a set of wheels and snow tires for the winter if you live in snow), and the problem is very likely to go away.
Z
