M35x front strut
mikesd1980
Car: 2007m35x
I was looking up front struts and reading prior post that I have to go OEM for them. Can I get them someone cheaper? I want to lower the car and im think im going to go with Espelir springs with OEM strut and KYB in the rear. Is that the right direction? Dont want to go with coilovers, dont want have to go through adjusting them after I get them installed.
http://www.infinitipartsusa.com/2007-In ... earching=Y
cruzad3r
Car: 2006 Infiniti M35x fully loaded
front M35 AWD is either OEM or Coil. If you're dropping the car, you need to think about camber. there is no other option. the rear you can go KYB.
mikesd1980
Car: 2007m35x
Ok, what about the camber? I figure I buy the strut and springs, have a shop install and wheel alignment. What else is need to be done?
Im clueless to this stuff and want to get the right info and parts with this AWD........
cruzad3r
when you lower, your camber will be out of whack. some here who have used coil said with a minimal drop, they can still retain camber but YMMV - search here or google m35x camber kit, if i recall correctly, there aren't that many options out there.
