M35X ECU Location?
Mindcore
Hi, hopefully my last question as my car sits essentially dead in the driveway. To save me tearing the wrong things apart, can someone tell me where the ECU is located?
Thanks.
Mindcore
82 views, no one know where the ECU is?
Mindcore
No need, found it.
For anyone else that happens to be looking.
Remove the passenger side panel on the dash.
Remove the glove compartment,
You'll see a large plastic panel covering quite a lot of stuff. There are two screws on the bottom of each side and then 4 screws across the top.
Remove those screws than carefully wiggle that large panel until it comes out.
Remove the trunk defeat harness, the footwell light harness and the glove compartment light harness.
Once it's open. I took out the black box in front to give myself some room to work.
To remove the harness to the ECU pull the release out to the left. It will stop halfway..PULL harder! then it pops out.
