JohnFx »
https://forums.nicoclub.com/johnfx-u92074.html
Fri Jan 02, 2009 10:23 am
I just finished doing this myself and let's just say it was a trying experience. I started to suspect Nissan's engineers of being purposely sadistic in the placement of the battery.
1) There is a cover over the battery that opens just enough to jump start the car, but not enough to replace the battery.
2) You can get the battery out by removing a minimum of two plastic covers with at least six fasteners. Ideally you have to remove three to make it an easy task to remove the battery, but I couldn't figure out how to get the last one off without removing the wiper blades. With the second cover off it is tantalizingly close to letting you remove the battery. About 1/2" of it is covered by the plastic cover over the wiper assembly. You can (with an extra pair of hands) wriggle the battery out by bending the plastic a tad, but it is very awkward. This also required disconnecting the fuse box from its mount to make room.
3) I bought the car used so it is entirely possible the previous owner did this, but the battery date was pretty close the model year and Nissan branded so I doubt it. The bolts on the terminals were two different sizes (one metric, one not) This is when I started getting paranoid.
4) The deal that bolts down the battery (two metal rods with a screw at the end) was difficult to get off, and impossible to get back on due how tight the area was and the fact that it was an operation you have to do blind. I gave up on it. With the difficulty I had getting that sucker out, there is no way I could see it coming unseated on its own.
5) The stock battery had absolutely no markings to indicate the CCA or any other info about the battery. Not that it was a problem to look up at the auto parts store, but we had to look up that information before they could run a test.
For such a common do it yourself task, the engineering of the engine compartment made the task unnecessarily difficult. Not technically challenging, but an obstacle course. To demonstrate how ridiculous it was, I seriously entertained for about 3 minutes the possibility that there might be a way to remove it from underneath the dash inside the car because it was set so far back.
