I wasn't anticipating the heat shield fitting correctly but figured it was worth the gamble. It doesn't fit at all. I wanted to avoid fabricating a sheetmetal heat shield. I have done it before on other cars but to do it nicely and do it right takes some time and talent and i'm not ready to give that a whirl yet.
Part of the reason I wanted to replace the stock airbox is that like some other M35's ive seen, the airbox halves start separating and it opens up a gap for unfiltered air to be pulled in. I also enjoy induction noises more than exhaust noises and need something like some induction noise to keep my inner child alive since selling my BMW
with the JWT filter and no heat shield, the IATs at idle while sitting in traffic can reach into the 140F range and take about 1/2 mile to drop back to 20-25 degrees above ambient. Once you start rolling and have 140F intake air, even with 93 octane I heard some ping under heavy acceleration. A first for me in this car.
I decided to do an experiment and split the stock airbox in half to make use of the factory air inlet points.
Its a very humid and muggy 89F with 80% relative humidity.
Engine temp is 190F, AC is on, engine covers are in place (even though not shown in the photos), cruising between 40-50 mph for 2 miles to bring things to equilibrium.
With no heat shield, the intake temperature is between 20-25F above ambient.
With the front half of the airbox utilizing the factory air inlet ducting, much to my surprise the intake temperature is a few degrees hotter, coming in at a solid 25F above ambient.
Obviously there is space around the filter that hot air is getting in. I suppose an auxiliary shield to work in accordance with the front half of the stock airbox could be a next attempt.
I want to keep things as reversible as possible. The airbox can be siliconed back together (which should give better filtration since the seams wouldn't be separating anymore)
The one thing I did notice is that while stopped in traffic, the IAT was 20F lower than before. I did not do any sort of formal test on idle IAT temperatures, but with the front half of the airbox attached it took much longer for the IAT to get up to 120F while stopped, and only got up to about 120F. Without the front of the airbox in place it was hitting 133F within a short amount of time.
I dont have much of an explanation for this. I anticipate leaving it this way and coming up with a shield that can compliment what the airbox is trying to do and try it out again.
Feel free to share heat shield solutions and ideas. Im not chasing every last HP for racing or anything, but as an Engineer, I have a little bit of OCD and like to know that things are somewhat optimized.
