M35x 2007 Climate Controlled Seat
rothnh
Car: 2007 Infiniti M35X
Hello.. I have a 2007 M35X with climate control seats. Setting the dial to cool works fine, but when I turn the dial to heated air, the issue begins. The light on the seat's climate dial stays on for a less than a minute then turns off. No heated air comes through at all. The light comes back on when the car is restarted and same cycle happens again if seeking heated air. Cooled air works perfectly. I have begun to read the se.pdf manual from Infiniti, but thought I would check if anyone else has had this same issue or has an idea. THANKS Steve
Ilya
This topic has been discussed a few times. Here are some search results:
search.php?keywords=heated+seat+turns+o ... 5B0%5D=176
