arrogantyeti101 »
https://forums.nicoclub.com/arrogantyeti101-u133371.html
Mon Apr 16, 2018 9:12 am
I'm just now seeing your question Davealan, sorry for the delay!
I was lucky enough to buy one with a 90-day warranty from a local Audi dealer that covered the heater core issue, but they still had the work performed by an Infiniti shop. I'm told by my Infiniti service rep that cost would have been a little north of $3,000, mostly labor due to how much work is involved with getting to the heater core itself (they have to take apart the entire dash, then put it back together). Other shops might charge less, but due to how involved the teardown is I'd be hesitant taking it anywhere else. It's also, according to the service rep, not uncommon. They had 3 other M's in the shop for the exact same issue.
If you haven't yet had the work done, I would also make a point to check things are all back together. I had to go back in twice to have things fixed as a result. They had forgotten to plug the USB cable back in for the center console, and they'd done something wrong with the hoses to and from the heater core that required replacement of the hoses and the pump that sends coolant through them. That last part might have been the fault of the Audi dealer, however, as they jumped the gun on retrieving the car from Infiniti and had to put some things together themselves.
