timothy.kelley86 wrote:Anyone think I need a heat shield? I was also thinking about trimming the second piece of the pipe half way so that it sticks down in that crevice partially?
anything to cut down your intake pulling in hot air should theoretically help...
i know a member checked underhood temperatures, although i think it was an M45, that were pretty darn hot.
you'll probably have to custom fab a piece out of aluminum. but if you google diy heat shield for cold air intake, you can find some pretty good instructions. you'll need to mock one up with cardboard and then transfer the pattern to the aluminum, cover it with heat resistant paint, etc.
I covered my R2C shield with self-sticking heat resistant/metallic tape, along with my intake tube as well. It doesn't look to glamorous, but no one can see it. I think Dean did the same with his Injen intake pipe as well.
