M35 When driving over bump/imperfection on roadway at LOW speed
sep1225
Car: 2007 M35
M35 When driving over bump/imperfection on roadway at LOW speed, car pulls quickly in direction of bump/imperfection. The first time it happens, it gets your full attention! At higher speeds, it's not evident. Naturally, the dealer says it's normal, but i've never seen this problem occur in 40+ years of driving. Any ideas? Thanks!
szh
Car: 2018 Tesla Model 3.
sep1225 wrote:M35 When driving over bump/imperfection on roadway at LOW speed, car pulls quickly in direction of bump/imperfection. The first time it happens, it gets your full attention! At higher speeds, it's not evident. Naturally, the dealer says it's normal, but i've never seen this problem occur in 40+ years of driving. Any ideas? Thanks!
Welcome to NICO!
I suspect that some tires, particularly directional ones, are perhaps more prone to this than others. But, I'd get the alignment checked too, just in case it is off or some suspension component is a bit loose.
How hard does it pull? Is it something you could get used to, or very unusually strong?
Z
