idwoodhull wrote:Ok. I saw my fuses by my battery and the fuses under the drivers side dash. I don't have that many of fuses by the battery where you said 90% of them are there. It a very small rectangular fuse box under the battery cover.
Am I clear to pull all fuses out when checking? Including 10,15,20, etc? The highest my multimeter goes is 10Amp if that matters.
There's a much larger box behind the battery. You have several various fuses/relays located under the battery cover, and also under the dash by where you mentioned. Hopefully you'll get lucky and it'll be one of the fuses under the dash, but you never know.
You're going to leave your multimeter on the battery, and pull a single fuse at a time. Yes, you're safe pulling a fuse with a higher amp rating than your multimeter, you're only testing a draw, not running the circuit through the multimeter.
The IPDM looks like this. It's covered, so you'll have to get the cover off. Once it's off, the actual IPDM is attached via a clip to the firewall. It's easiest to get a long flat blade screwdriver and push the clip while pulling up on the IPDM at the same time.
It looks like this;
It's going to be tight, the dash harness doesn't have much slack on it where it comes through the firewall there, so don't pull too hard.
