m35 transmission problems
brevardchachi
Car: 2006 infiniti m35 base model
ok so I have an m35 base model with 107k
now going from a dead stop and punching it my car is at like a lose of power through first gear with out going over 5k rpm the shifts and works great after that if I slowly creep in first and romp it then everything works fine its just from a dead stop on cel at all I have a video of it but have no idea how to add it s you can see what I am talking about
Ilya
Sorry, is there a CEL? Or there isn't? Did you try turning VDC off? Might just be the computer cutting power so you don't spin out into a tree.
Larz
Car: 2019 Q70-L RWD
I'm not following either. Maybe re-post as several complete sentences instead of just a bunch of words and clarify if you have a CEL or not.
Ilya
Honestly it sounds like VDC is doing it's thing. Does the 'SLIP' (I believe) light come on your dash when you try to mash it from a stop? On my car, it's a car with two wavy tire marks, but I have a 2011.
brevardchachi
sorry guys but no there is no cel light on. I have not tried taking of vdc and see what happens but its weird because it only does it sometimes.
JayM35x
Car: 2007 Infiniti M35x
It could be your valve body which is connected to your transmission. Sounds like what has happened to my car my vavle body went bad recently and still needs to be fixed. Definitely get it checked as soon as possible before driving too much with whatever issues your transmission may be giving you.
brevardchachi
ok so I have noticed the traction control does come in. if I am in sport mode with vdc off then we are good and it does not to it but have to be in both for what my car is doing to me might be different for others thanks for the help guys greatly appreciated
EdBwoy
Brevard, thanks for the update but I'm afraid I'm still confused here. Has the problem been solved?
brevardchachi
yes it is just traction control kicking in so it doesn't slip thats all. the car just has to be in slap stick and vdc off then you are good
EdBwoy
Thanks for the clarification. Pretty odd though. Are all your tires the same size and in decent condition?
If you still want to post the video, but don't have a YouTube account I can post it for you and share it here.
