szh »
https://forums.nicoclub.com/szh-u149.html
Tue Apr 14, 2009 11:13 am
(Please also do a search for this topic. There are a number of posts on it. )
Regardless, the general guidelines are:
1. Check every week to two weeks - more often if the weather has changed.2. Low-profile tires show more pressure changes with a given air loss - less total volume to begin with!3. Use a good gauge - whether you use a digital or analog is not that important.4. Check truly "cold" tires ... no driving, and no sun hitting the tire.5. Don't let the pressure drop below the values shown on the door. They are low enough to be uncomfortably close to the load index rating of tires today.6. If you regularly drive high-speeds, increase the cold pressure - sidewall flex and consequent heating is the prime reason for tire failure (the Firestone-Ford SUV debacle!)
My recommendation: start at 36psi and adjust up a few psi (not past the tire max - typically 44 or 51, but that would be a harsh ride) or adjust down a few psi (not below the recommended value shown on the door) till the wear is reasonably even across the tread. Buy an inexpensive tread depth gauge (few bucks) ... the "penny" and newer "quarter" tests are too inaccurate.
BTW, my recommended value of 36psi is a rational compromise between being too high (where the road harshness would be painful for a luxury sports sedan) and being too low (where the safety of our heavy cars would be an issue).
FWIW, on my current Michelin Pilot Sport A/S, I have dropped it to 35psi (and about to go to 34.5 psi), since the wear is higher in the middle than I expected, compared to my older Goodyear Eagle F1 GS-D3 tires ... not sure why, but I think it is because of the sidewall stiffness being different (lower load index too!). I also plan to measure every week once I go to 34.5 psi, since the margin of error (for being low) is increased.
Z
