Ilya wrote:Buy an ODB-II Bluetooth reader and connect it to your phone via something like the "Torque" app...that should be able to read your oil pressure sensor information and give you the value. $25 or so.
Thanks Ilya, did both of those. The oil pressure is not a sensor that reads as part of your OBDII reader. I think I did sufficient research to figure this out (and also playing around with the app for along time. Link below is one of many who seem to find the same issue. From what I understand the sensor in the car only tells you Low or Not Low. Nothing in between....
EdBwoy wrote:
Going off memory here as its been over 2 years since I dismantled a VQ35DE.
Isn't bank 1 on the V6 the passenger side - and the water pump on the driver side? The only way I see your water pump job being an issue is if the bottom of the chain sagged and when you put it back together you jumped a tooth off the crankshaft.
Otherwise, the stroke of the oil tensioner plungers should be enough to compensate for about 2 jumped teeth worth of degrees on the head side, but the little sprocket driving the block side might not allow much variability.
To answer your questions,
1. Yes, you should be able to remove it and get clearance for more work with the radiator and fan shroud out of the way. I know some guys with the FWD VQ35DE could do timing chain tensioner replacements with the engine still in the car, so the RWD layout should give you lots of room.
All the bolts to be removed are on the front of the engine except 2 long ones that come up from the oil pan.
2. From what I've seen of the M35 engine, I don't think they're in the way either, but pics from you or cruzad3r will help.
Do you mind throwing some links here to discussion on the oil galley gaskets? I'm curious about this.
Yes, bank 1 is the passenger side. But you have to access both sides to do a water pump job (remove chain tensioner on driver side, to get enough slack to remove the water pump). I've thought a while about the timing chain skipping a tooth. But I just don't think my car would idle well AT ALL, and when warm it idles almost as smoothly as stock. Timing is known via the Torque app actually, at idle it's about 15 degrees advanced. Driving down the highway is about 35 I believe. However I've never been able to find the metrics as to what is normal. I actually am not positive you can skip a tooth on a water pump job. I've seen lots of threads on people suggesting they may have, but the actual issue was always something different.
I can do the timing chain tensioner while the engine is in the car. The timing chain tensioner is accessible through an access port, so I can see where that's not hard. Same as with the water pump.
As for the oil galley issues; a few links are below. Basically it sounds like the gasket will blow and oil will spray into your timing chain cover. So you won't have a leak, just an internal oil pressure loss. It won't be bad enough to kill the motor, but will be bad enough to screw with the VVT Solenoids and variable timing.
I brought my car into the dealer to take care of the airbag recall and asked them their thoughts. They told me "you definitely have an internal oil leak" and wanted $500 just to take the cover off and inspect it. But I'm not sure if they told me I have a leak because I told them I suspected there was; or because they actually diagnosed it that way. End of the day though, skipped a tooth or blew the gasket, the end result is me taking the front timing cover off. And like I said, before I rip into that job I want to know if anyone has done it with the engine in the car (and any advice there) and if they absolutely had to take off the intake manifold to do so or not.
As I try to post, I find I'm not allowed to link URLs.
Search on my350z site "timing-chain-cover-galley-gasket-change-what-to-look-for"
G35driver site "cause-dreaded-p0011-p0021-codes-everyone-curious-about"
and 350z UK side "zed-owners-must-read-p0011-p0021-caused-by-oil-gallery-gaskets"
