johninm wrote:Dont you think 36 will be a little high, at normal it will go to 39 and I read somewhere dont put more than 40 ?
Nope, 36 psi will not be too high. Most modern, high-performance tires are rated at 51psi max pressure nowadays. Tire load indexes are measured at 36psi, by the way. There is reason to believe that the "correct" pressure to use is at 80 to 85% of the max pressure value ... this means that some people even run the "51psi MAX" tires at 40 to 44psi. IMHO, this is too harsh a ride, but not unsafe.
So, running at 36psi will give you a very slightly harsher ride than running at 33psi (mostly imperceptible on today's roads) and give you the safety margin that it better. Running at 40psi will be higher harshness (it will become perceptible for sure) and may also wear the tires more in the center than in the outer section of the tread.
But running at 33psi just leaves no margin for error (in the measurement, in the gauge accuracy, the drop over time, etc.).
As a final BTW, when you run at high speeds, it is a requirement that you increase the tire pressure to reduce the sidewall flex (prevents heating and tire failure). In Europe, cars that run on the autobahn are required by the manufacturers to be set to at 7 to 8 psi more tire pressure than "normal" for this reason.
Hope this discussion helps!
Z
