FiShEyEz wrote: ↑Wed Feb 19, 2020 11:17 am
Seve
Keep in mind that the motor only spins in once direction so it will not necessarily move in the direction of the bad mount. If there is any play in a mount, it will reflect in the movement of the engine.
Isolating the mounts will likely be done with a physical inspection. Look for cracks in the rubber. Mounts are generally filled with a lubricant or grease so look for moisture or caked on dirt as well.
If you’re feeling vibration through the entire car, I’m almost 100% certain that your mounts need service.
Jacked the car up today and took a look at them. They don’t look terrible, had a friend shift through P, R, D; nothing glaringly wrong with them, however, the driver side one looks like it had a deposit of grease and dirt under the rubber flap, so if one is bad, it’s that one, another question stems from that. If my mount is bad, would a g35 mount work? The M mounts are 150$ a piece bare minimum, the G is 40 for 2. On top of that, I can’t find this part on most autopart stores website and there only two listings on amazon for it. Find it a bit odd that the only mount that’s different on the 35 Infiniti’s is the M. They look the exact same, so am I crazy for thinking the parts are interchangeable? 2007 M35 rwd
The “m” mount’s part number: 11220-EG001
The “G” mount’s part number: 11220-CG110
