M35 LOWERED ON EIBACHS AND KYBs?
Max2di4
Does anyone have their M lowered on Eibachs with KYBs? Did you have to you camber screws or can you drop withoug? Any pics with your drop?
What would you say are the best to drop your M with?
06M4.5
Car: 2006 M45
best would be a coilover set-up
I have heard that KYB are to soft for Eibachs, most use them as an oem replacement as the stealers price is just too high for oem struts
gmoney35s
Car: 2007 M35S
ok what about Teins S Techs on KYBs i want an adjustable shock dont want a full coilover
InfinM3506
Car: 06 Infiniti M35 Luxury Edition, Journey Package, Tech Package, Burnt Orange Leather. Eibach Pro Springs, 20" Vossen CV3 20x9 255/30/20. 20X10.5 285/25/20. 08 Front Infiniti Sport Changeout.
My car is lowered on Eibachs and KYB's. The KYB's might be a little soft. But compared to stock its stiffer.
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
I think the question is what type of drop are you trying to get..? Slammed, mild drop, aggressive stance etc.... The eibachs are great springs, but I went with H-techs since I wanted to get rid of the stock wheel gap look, but still maintain comfort.... I have the KYB sport shocks and it rides well... I think once I pick up another daily driver, I will change to eibachs or coilovers for the M
Max2di4
Did either of you use camber screws or they are not neccesary with the Eibach or H-techs?
InfinM3506
I didnt have to use camber screws. You shouldnt need them.
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
Max2di4 wrote:Did either of you use camber screws or they are not neccesary with the Eibach or H-techs?
I was dropped on eibach almost right away with 22" and no camber bolts! I exchanged my wheels (22") pretty quick so tires didn't show much wear but when I went to 20" WORK wheels I was really happy with the set up and kept it for a while... When I sold them I noticed I had camber wear inside so with my Vossen set up I went with full adjustable upper control arms up front and rear camber adjusting bars (both eibach/same as spc)! I highly recommend the eibach springs over anything even coilovers but that's just me :gotme I've had d2 coilovers and it was SICK slammed but the eibach is just right IMO :dblthumb: my stock struts/shocks were only at 33k-78k+ miles so I used the eibach springs with OEM not kyb and they worked out great!!
My best advise would be if you drive your car daily I would invest in the camber kit! If it's just a weekend car you should be fine... Also I should mention the front is more noticeable than the rear... Definitely invest in the front! :dblthumb:
Max2di4
Thanks for the info
