bambamramram »
https://forums.nicoclub.com/bambamramram-u133481.html
Sun May 17, 2009 12:24 pm
Yup--saw all the threads w/ the pics and I did make the adjustments (with the phillips head screwdriver) recommended and those adjustments worked great for the low beam. I just took a 3 hour trip this past weekend, through heavy rain and at night and I could see fine--I was happy with the info I found on this site--a great site it is, because the dealer could not help me!
The hi-beams were still pointed really high and useless on flat roads or when going down hill. They worked better the steeper the incline as I was driving, but that said, I did not really need to use them because the low beams worked well after I made the adjustments.
Anyway, shame this has been an issue on the M since the 2006 models and the factory or dealer has not come out with a fix--I feel like I should not have to do a "shade tree" fix to an essentially brand new car. Both hi and low beams should be able to be adjusted independently (considering the low beams work so poorly). Anyway, just seeing if any improvement had been made besides manually adjusting...looks like this is still an issue that won't be solved (from the factory) until they release the new models. Anywho...thanks all.
