m35 headlight low beam is out!
FUGABOY88
Car: 2006 M35 SPORT
so i currently ran into a problem where my passenger side headlight went out! thought it was just a bulb replaced it and it didnt work so today i replaced the ballast and nothing! so i was wondering if their is a relay or fuse that needs to be replaced any help will be greatly appreciated!
debiniarthug
Car: 2006 Infiniti M35 - Luxury Tech Package
2004 Maxima-Driver Package
2000 Maxima
Same thing here! Do you or does anyone know where the relay for the low headlight is located?
debiniarthug
2000 Maxima
Low beam relay? Anybody?
Ilya
Are you guys running after market HID kits? You (like I did) may need an auxiliary harness from DDM Tuning in order for them to work to their full potential. I had issues with initial startup of the ballast and flickering.
http://www.ddmtuning.com/Products/HID-K ... ng-Harness
debiniarthug
2000 Maxima
My M came with factory lowbeam HID's. I started having this problem before I changed the standard 4300K bulbs to 6000K. I think I need to change the relay but I don't know where it is on the car. I posted on the forum but didn't get any leads. It's frustrating to think it's something simple and I just lack the education to fix. I would rather think it was way to complicated for me to tackle.
eergsxr
reving a old thread... i have this same problem, does anyone know were this relay is?
junkstopshere
Car: 2006 Infiniti M45
I have the same issue.
Checked driver knee panel, panel next to battery, and panel in comparment in front of battery. According to wiring diagram I found, there should be a left and right low beam relay.
So where are they?
debiniarthug
2000 Maxima
I never found the Relay. My issue was the balast went bad. I refused to pay the premium for OEM balast so I purchased a HID conversion kit for about $70. Installed myself, took about an hour to do both.
