That is what I do and recommend too. Nissan and Infiniti transmissions will last longer (i.e., well past the 100k mark) when you do this regularly ... it is a good maintenance habit.dvan wrote:Get ATF Flush every 30K miles starting at 30K.
Exactly! I just done a drain & refill yesterday with Dex-VI. The M1 atf had 36k on it. Since my transmission has a lot of miles on it (check the signature), I plan on doing a drain and refill every 15k from this point forward. I can drain the oil and the transmission fluid at the same time.szhosain wrote:
Remember: transmission replacements are expensive! Once out of warranty, this could be the most expensive repair you ever have to do to your car.
And, as always, remember not to use standard ATF ... you must use the Nissan required one to make sure that the transmissions does not die (and/or the warranty is not voided).
Z
Fluid manufactures have long since identified what the ingredients were in J-matic and there are plenty of substitutes. There are other threads (I don’t remember right now where) that give the exact make up of J-matic and what other fluids have the same ingredients. I just had my 06 M35’s fluid changed at 60,000 miles by a local transmission shop (Automatic Transmission Factory in Davie, FL) that used Amsoil synthetic and a bottle of Lubeguard. What a huge difference! The transmission shifts smoother when I drive nice, but kicks harder when I jump on it. I never expected these kinds of noticeable results just from switching fluids.szhosain wrote:
Z
