M35 center display dim
sammysquest
Car: 2007 M35
2002 G20
2000 I30
Anybody had this problem? Center dash display is dim unless I override with the headlight switch. I unplugged the optical sensor on the passenger side dash register and no change. Is there a way to test the sensor or the BCM?
Reason: Moved to correct Forum
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
You sure you don't have the day/night button pushed? Most Nissan/Infiniti AV Units remember the button setting.
EniGmA1987
Car: '06 Infiniti M35 Sport
Probably just age. The backlight dims with age and use and the car is 15 years old now. Mine has been dimming for years. I really need to replace it and I plan on following EdBwoy's video tutorial of when he did it for doing my own.
sammysquest
Car: 2007 M35
2002 G20
2000 I30
Thanks for the responses. I covered the sensor on the passenger side and the the headlights came on and the screen brightened . No problems at night or dust. The problem is when the headlights turn off from the sensor the Radio ,HVAC, Map, etc display can not be seen. Where is the day night button?
I honestly have never noticed it. Not my primary car until it needs something. Momma's car. Im still driving my G20 that does not have all these gadgets
Thanks
Sam
sammysquest
Car: 2007 M35
2002 G20
2000 I30
Just to follow up I pushed the day night button that up to this point I have never used. Problem solved. Thanks all
I had the dash apart to repair multiple cracks and thought I had created an issue with one of the electrical connections.
On to the next task.
VStar650CL
Technical Expert
You're most welcome. Happy motoring!
