1.) Turning each should be sufficient.skibumdc wrote:BACKGROUND:
1) Are the new rotors necessary, or overkill?2) Do I need the special tool to push in the rear brake piston or will C-clamp/Channel lock work fine?3) Approximate cost of new rotors and pads? Buy at dealer or online?4) Torque numbers for caliper sliding pin bolts?5) Torque numbers for Caliper retaining bolts?
The question is, how are you going to flush the old fluid out of the ABS accumualtor and pump so it doesn't destry the ABS unit?skibumdc wrote:If I never disconnect the ABS sensor, why would I need to reactivate it?
Or even if I disconnect the sensor, if I have disconnected the battery already, why would I need to reactivate?
I've never had to reactivate on other cars, including the G35.
I use a Motive Power Bleeder while the car is turned off.It uses pressure to push new fluid through the lines without hjaving to use 2 people. Lots of people use them.Are you saying that won't work?maxnix wrote:The question is, how are you going to flush the old fluid out of the ABS accumualtor and pump so it doesn't destry the ABS unit?
For Christ's sake man!!!!maxnix wrote:The question is, how are you going to flush the old fluid out of the ABS accumualtor and pump so it doesn't destry the ABS unit?
As you say, if the width spec is within tolerance, and will stay within tolerance after the procedure ... then yes, go for it!Jacko3 wrote:If there is still enough meat on the rotors, just turn them.
And they word "hygroscopic" means? And moisture in brake fluid forms what? And acid does what to seals?bullittandy wrote:Leaving old lfuid in the ABS unit IS NOT going to "destroy" the unit.
Please reference the above posts where the ABS pump failed because the owner regularly changed his brake fluid but each time left a microscopic percentage of old fluid in the ABS pump. Brake fluid moves through the ABS pump, bleed the brakes, engage the ABS and the problem is solved.maxnix wrote:And they word "hygroscopic" means? And moisture in brake fluid forms what? And acid does what to seals?
You really need to read more as there are numerous examples on this forum of ABS pumps being replaced due to inadequate brake fluid chang intervals. Please don't post known incorrect information.
No, that is a flawed deduction. Replacing 100% is better than replacing 99% is the correct deduction. Vigorous driving activating the ABS on deceleration might get that to +99%. I bet the accumulators and pump hold about 5% of the total brake fluid. But I have never seen any actual data.skibumdc wrote:So basically you are saying replacing 99% of the fluid is just as bad as replacing 0%?Boy, you really are an all or nothing kind of guy, huh?
