szh »
https://forums.nicoclub.com/szh-u149.html
Mon Jun 04, 2007 5:37 am
Somewhere near 36psi is probably the right place to be for load index reasons. However, if 34psi is the most comfortable for you, then keep it there! But, do check it often ... tire pressures tend to drop 1 to 2 psi every week to other week. This is natural. You will not see much perceptible difference in wear between the recommended 33 or your setting. Also, how accurate is your tire gauge?
You did not mention which Eagle tires you have. The Goodyear Eagle F1 GS-D3 is an excellent tire in wet weather and it is what I have been using for a while (since my other favorite was discontinued(. Not the absolute ultimate in response or handling, but outstanding in wet - braking or road handling. A bit noisier than a Touring tire, of course, but way superior in all other ways!
So, if you have the Eagle F1 GS-D3, then stick with it. Else, consider using one of the other tires mentioned in my spreadsheet in the stickies above (the Michelin Pilot PS2 is probably one of the best tires in the world for this car - pricey too, though).
Z
