M35 100,000+ miles maintenance report
bluedevil30
Car: 2009 M35X
265,000 miles
I thought it might be helpful for people to share larger maintenance issues for M35s with over 100K miles.
I have a 2009 M35X with 120,000 miles. Since passing the 100K mark I have had the following issues:
- left rear wheel bearing replaced at dealer $500
- seized right rear break caliper - replaced both rears at tire store for $550
- around 100k had the radiator and trans flushed and fluids replaced at dealer
- passenger door doesn't lock on occasion from outside button. - haven't fixed.
Those are the only unusual major issues I have had in the car besides normal oil changes, air filters, brakes and tires which were never done at a dealer.
Ilya
I got my 2007 M35x in May 2010 with 32kmi on the clock.
Since then I have done the following:
1) Driver seat track and computer replaced as soon as I got the car due to the memory function not working and seat moving upon braking (warranty - 35kmi or so)
2) Both front wheel bearings, passenger side hub and axle (warranty - might have been cause by me taking a jump with the car lol - 58kmi)
3) Bluetooth module replaced/relocated per TSB (warranty - 58kmi)
4) Fuel filler neck/valve replaced (warranty - 58kmi)
5) Steering rack was leaking/not tight and was replaced (warranty - 88kmi)
That's it. Otherwise, I've been replacing (the last 20kmi or so) the suspension components, doing exhaust now, etc. I have had no engine or transmission issues the entire time of owning the car. I don't even check the oil as I change it often enough that I'm not worried (every 5kmi regardless of how I used it).
Bottom line: this car has been ultra reliable
bicsintegra
Car: '06 Infiniti M35
'06 Infiniti G35 Sedan (daughter's car)
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
i have approx. 119k on my M, I drove it to new York at about 98k miles 2 summers ago. it was hot as hell the radiator blew a week or so after I got back. so I replaced the radiator, flushed the ATF fluid. The seat is off track and I will get that fixed shortly.
bicsintegra
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
I got the belts changed and the recall done at about 106k miles.
sin1505
Car: 2006 M35x
My car is now 230k km - I had a leaking rack & pinion, some rust spots on my roof caused by highway chips, and had to fix both rear muffles due to rust.
Yeah it snows a lot here
